Computer hangs while viewing Vi's
I am having a problem with my LabView 7.1 Prof Dev   running on my new machine. I am loading a large Application. As I browse around opening and closing different VIs the computer hangs hard. The mouse and keyboard become non-responsive. The only way out is to hold the power button. The machine has not hung with other applications like ProE, AutoCad, Cadence layout/capture, or any other windows product. I have also tried loading LabView into a virtual environment where it also crashes. The application I am loading was created on another machine where it operates normally. I have updated both the computer  bios  and the video driver to the latest available. I have included a listing of my machine information.
Do you have any suggestions?  Thanks in advance..  Dave E
OS Name          Microsoft Windows XP Professional
Version 5.1.2600 Service Pack 1 Build 2600
System Model   Dell Precision WorkStation 370
Processor         x86 Family 15 Model 2 Stepping 5 GenuineIntel ~3391 Mhz
BIOS Version/Date         Dell Inc. A06, 8/30/2005
Total Physical Memory   3,072.00 MB
Name    NVIDIA Quadro FX 3400/4400
Adapter RAM     256.00 MB
Installed Drivers nv4_disp.dll
Driver Version    6.14.10.8167
(2,879 Views)
Are the problems related to this one particular VI? Can you open up example programs or build simple VI's? Are there any drivers such as NI-DAQmx in your application?
Did you encounter any errors when installing LabVIEW? It sounds like it might be worth your while to uninstall and then reinstall it.
Jarrod S.
(2,851 Views)
