Complex cluster in CIN
Dear all,
I need to write a CIN with an output as an array of clusters. Each element
of the array (cluster) has to contain the following fields:
1. int32 value
2. 1D array of int16, which size is defined by the integer value
specified above.
While it is simple to create an output array of clusters using "SetCINArraySize" function, I don't know how to create the arrays WITHIN each cluster.
All suggestions will be highly appreciated.
Michael Mazlin,
Instrutech Corp.
Message 1 of 1
(2,752 Views)
