Complex FM with PLL
Hi All!
I've found example of PLL FM demodulation by T.J.Moir http://decibel.ni.com/content/docs/DOC-1101;jsessionid=82a40f1a30d6b414f9c6b27d40eca1b8b6f16bb38b32.e3mNbNaPb3iNe34TbxaPbhuOax10n6jAmljGr0
 I tried to to demodulate my own signal which contains two Sine harmonics as a message. Seems like I connected correctly but graph indicator still doen't show correct message.
Maybe people who worked with PLL could tell what might I forgot or did wrong?
Thanks in advance.
(3,616 Views)
Hi ACiDuser,
I was not able to open your VI because I do not have realAVC.vi and realPLL.vi. Can you post these as well?
Claire Reid
(3,594 Views)
Hello, required libraries were in my posted link, but I also will attach it to this message.
(3,590 Views)
HI,
I didn't realize that this .llb was from the NI Developer Zone Community. Please post a comment on the community. Also, you might want to check out the NI Modulation Toolkit as I believe it has VIs that will help you.
Claire Reid
(3,571 Views)
