Compiler error in LV2009
I received this dialog when updating a type-def that was a member of an LVOOP class just now.  I renamed one element of the cluster and added a new element (both were booleans).  I have no other useful info on how I generated this error.  I hit OK a bunch of times and eventually the problem went away.  I saved everything and restarted LabVIEW and nothing appears to be broken.
(I'm using LV2009 on WinXP)
(2,608 Views)
Does this error appear every time or just sporadic? Can you please post your code.
(2,542 Views)
