Compiled vi always runs when opened, Labview 2013 bug?
I'm presuming it's not a bug, but right now it looks like that:
I compile a vi to an exe using the application builder, but no matter how I adjust the settings, the vi will always run when opened.
I'm running LabVIEW 2013.
Lars Melander
Uppsala Database Laboratory, Uppsala University
Message 1 of 23
(4,282 Views)
Hi Lars,
when I run an executable (regardless LabVIEW or any other programming language was used to create it) I expect it to run when opened.
Do you expect something different when you start MSWord, FireFox or any other program you need?
Message 2 of 23
(4,275 Views)
That would be what happens to any "Start-up.vi" when an application starts up
"Should be" isn't "Is" -Jay
Message 3 of 23
(4,268 Views)
I want to enter values and set up things before I actually run the vi.
Why am I able to uncheck "run when opened" if it actually doesn't do anything?
If you're not going to answer the question, please refrain from posting.
Lars Melander
Message 4 of 23
(4,257 Views)
The start up vi will run.  This is expected behavior.
If you want the running vi to wait for user input before executing a process you need to code a proper arcetecture to do that.  Look into the Producer Consumer (Events) design pattern.  It is a good way to start an application like you describe.
Spoiler
See, asking a question (or at least explaining what behavior you want) gets more specific answers.
Message 5 of 23
(4,248 Views)
Are you saying that the "run when opened" checkbox is obsolete?
What's the purpose of having a run mode (as opposed to edit mode) if nobody's expected to use it?
Lars Melander
Message 6 of 23
(4,227 Views)
"Run when opened" and "edit mode" apply to the VI file, not the exe.
Jim
Message 7 of 23
(4,221 Views)
In the app builder properties, under "Source File Settings" I can click "Customize VI Properties..." and there uncheck "Run When Opened". Does this actually do anything?
Lars Melander
Message 8 of 23
(4,217 Views)
Hi Lars,
the point is: any executable is set to "run when opened", that's the expected behaviour on any OS. You cannot change that behaviour!
But you can (or "have to") program a good UI that allows the user to start a measurement when (s)he is ready to do so. In the simplest form you just wait in a polling loop for a "Start now" button, in more advanced schemes you will use an event structure and maybe a state machine. A producer/consumer scheme can be used to, but will probably use the event structure and the state machine too...
Message 9 of 23
(4,214 Views)
A problem is that even though it runs when opened, it only runs once, not continuously.
Lars Melander
Message 10 of 23
(4,212 Views)
