Compile external code with Microsoft Visual C++ 2008 Express Edition
I'm trying to compile a c code to work with Labview (either CIN or dll). In the past I did that with no problem using visual studio. I'm having a really difficult time compiling the code with
Microsoft Visual C++ 2008 Express Edition. I'm trying to compile one of the examples that come with Labview (Multiply 2 numbers for example) .
I'm not sure how to set the c project  with Microsoft Visual C++ 2008 Express Edition. I read on the web something about making a lvm file with Labview makefile. Is that really necessary? If so, how do I create this file?
Thank you,
Eyal
(4,420 Views)
Thank you,
Eyal
lvm is the abbreviation for LabVIEW makefile and is only used for CIN's. The idea behind lvms was to make a single and simple make file that will then be used to thrive the nmake tool that comes with Visual C. It could be that either Visual C 2008 or maybe just the Express edition does not come with that command line tool anymore.
Creating CINs in Visual C is a bit of a hassle because of the custom step necessary to invoke the lvsbutil tool. Visual C manages to change the actual syntax necessary to add such custom steps to a project with every new version. So whenever someone has written a good guide about how to creat CINs with Visual Studio xyz it will again break with Visual Studio xyz + 1.
That said you might be interested to read through the three articles at http://expressionflow.com/author/rolfk to see why using CINs is a dead end since several versions of LabVIEW already and that you should really go with DLLs.
Rolf Kalbermatter
Message Edited by rolfk on 01-21-2009 10:17 AM
Rolf Kalbermatter  My Blog
(4,396 Views)
Accepted by topic author Eyal_S.
Thanks for your reply.
I actually found a way to create a dll on the web :
http://decibel.ni.com/content/docs/DOC-1690
(4,352 Views)
