Compile error (Code could not be generated)
When I try to run the attached vi I get the following error message "Code
could not be generated correctly for this VI."
I use Labview 7.1 under Windows XP.
(2,592 Views)
The "Representation" enum is defined differently in the "SDO Par In", "SDO Par", PDO Par In" and "PDO Par" clusters. Labview does apparently not recognice this and crashes instead of warning for incompatible data types.
(2,592 Views)
