Compile Error - No Spill Candidate Found
Im trying to create a FPGA vi using the high throughput math in Labview 2009. However whenever I click save or run, i get the following error: -
"Compile error. Report this problem to National Instruments Tech Support
out of regs - no spill candidate found, reg 969!"
This error occurs when I have any of the high throughput stuff in my vi, however as soon as delete them, the error disappears. Can anybody help,
Mark
(2,932 Views)
Can you attach your vi?
(2,924 Views)
Find attached.
(2,917 Views)
Ok, Ive found the problem. Labview 2009 doesnt like it when you try to put a fixed point number into "in range and coerce". So ive converted to an integer and then back again afterwards.
(2,897 Views)
