Compilation time - LabVIEW FPGA project
I am trying to compile a LabVIEW FPGA project over NI PXIe-1071 chassis.
My problem briefly lies in the compilation time which last hours while only takes approximately 20 minutes on another chassis I am having with exactly the same specifications.
Is there any project settings I should check which may casuing this problem ?
Thanks.
(2,907 Views)
The FPGA boards exactly the same and the VI is exactly the same? All you are changing is the chassis? R Series or FlexRIO? What version of LabVIEW FPGA? How much are the designs "filled up" (like what is the percent utilization of slices)? There are project settings for effort levels of the Xilinx tools depending on what version of LabVIEW you are using.
(2,883 Views)
