Compatibility of NI 9212 temperature reader with the different version of Labview
I should interface a NI 9212 temperature reader with Labview. Could you please help me to understand the compatibility of this device with the version of Labview? Is there any page or table in which I can verify the range of versions of Labview which are compatible with this device?
(1,863 Views)
it doesnot matter , just uou have to install RT module of your labview version
CLA
(1,833 Views)
What did you mean with "you have to install RT module"?
(1,803 Views)
LabVIEW interacts with an instrument driver
The driver interacts with Instrument
To find compatibility, you have to first get the list of instrument driver versions that support your instrument, then lookup that driver version's support of LabVIEW.
Having said this, given your NI 9212 is still an active manufacturing state, typically any DAQmx version 16.0+ should work fine.
Now, the other user's comment about "RT" depends if you use this module on a CRIO.
Note that Driver version >= LabVIEW version.
LabVIEW 2020 will not work with DAQmx 18.0
Santhosh
Soliton Technologies
(1,799 Views)
