Compatibility between LabView and Matlab
Hi. I have Matlab 6 (with a floating liscence, it's in a network) with LabView 5.1 installed on a PC but the matlab script command in LabView doesn't work, it gives the message: "the server failed to execute the script sent by Labview. A message error occured". Must I use a lower version of Matlab? Thanks for help.
Anthony
(2,995 Views)
Could you please take a look at the Knowledgebase ID 2C1AH6DM? IT provides an insight into this problem. Try to replace the suggested matscript.dll
(2,995 Views)
