Comparision of Triangular and Square wave and converting to digital signal using DAQ Assist
I would like to create a PWM signal by comparing a Triangular wave of 4kHz with a Sine wave of 400Hz and the analog output is to be converter to a digital train of pulses which i would like to feed to a M series SCB-68 device for mosfet gating pulse.I have attached a figure depicting the problem.
(2,949 Views)
Hi Adithya,
and what is your problem? All you wrote is "I would like to…"!
Start with coding, then ask for specific problems.
Hint:
This seems to be an exercise topic given to several students as I have seen similar questions in the last days. Maybe you do some forum search and look what other people have tried so far?
(2,917 Views)
Sorry for not including the VI. Also i am facing issues with DAQ assist. How shall i connect the subtracted wave which is analog to digital and get it on the M series device. Also I have done some readthrough on the diffferent ways of generating PWM. But I would like to try in this way. Is is possible using DAQ assist
(2,908 Views)
Hi Adithya,
instead of subtracting the waveforms you might use a simple "greater than" comparison which already results in a boolean signal.
To "get that on the M series device" you should use DAQmx functions…
Btw. the SC68 is just a connector box. What kind of device you really are working with?
(2,904 Views)
