Compare two image
I get two PNG image.  I try to use pattern matching in vision assistant but cannot automatically create template. Which function can automatically compare this two image?
(2,864 Views)
You may be able to programmatically create a template from an acquired image and use that in your pattern matching application. As a start, this example would be worth looking at.
(2,799 Views)
