Compare revision status of two large .llbs?
I'm taking over a project from an engineer who left. I now have two separate large .llb's that are not well documented. Supposedly one is a later rev. I would like to find out what is different between the two revs. The librarys have different top level names (i.e., rev1 and rev2) but all of the internal vi's have the same names. Is there any easy way to do an automatic check that would tell me what vi's have changed between these two versions?
(2,563 Views)
If you have the full development version of LV you can use the compare VI hierarchies function from the Tools-> Compare menu.
If not you could open the llb with the VI library manager (Tools menu) and check the show dates box you can see the dates of all the VIs.
(2,563 Views)
