Compare Digital Waveform to Binary String Array
My question is fairly specific, so hopefully you can point me in the right direction either on the forums or in a response.
I'm attempting to build an array of binary code saved in string constants and compare it to a digital signal that I'm continuously PSK demodulating from a radio transceiver. I'm eventually going to flag when any of the strings in the array match the incoming bit sequence to ~80% accuracy.
I haven't completely jumped into the task above, since I have quite a few binary strings to add and I just want to get a grasp on how to do the comparison before I start. Thus attached is just a flow diagram of my process.
Any snippet on how to start this would be appreciated.
(2,627 Views)
Here is a start, assuming you can convert your signal to a boolean array.  There will need to be some modifications due to array length mismatches.
(2,588 Views)
