Compare 2 string's -> output boolean
Is there any simple way to compare two strings. The output should be true or
false.
rutekp
(3,161 Views)
This is where LV's polymorph functions make things very simple: just wire the strings into an Equal? function (from the comparison palette), if they are equal the output will be a boolean true.
(3,161 Views)
