Compare 2 alarms and if they are the same, don't save the second one
Hi there,
I made a program with a logfile.
Everything that will happen in my program (Starting, Log in, Log out and alarms) will be saved in this file.
It's a .txt file.
I want to make a function that carries out that the file is maximum 100 lines.
And I also want to make the following:
When a action, for example an alarm, is the same as the action that was before, the second alarm has not to be saved in the logfile.
I want to build this in to prevent that there is 20 times the same alarm in a short time in the logfile.
I hope someone can help me.
Kenny
Message 1 of 12
(3,534 Views)
Use a shift register to store the last read alarm. Only log an alarm if the stored alarm does not equal the new alarm.
Rgs,
Lucither.
"Everything should be made as simple as possible but no simpler"
Message 2 of 12
(3,529 Views)
Ok, but where can I find such a register?
Can you make a small project, just that I know how to make it and how the blocks look like.
Greetz
Message 3 of 12
(3,519 Views)
Hi Cheese,
to add a shift register you right click on the loop and select add shift register. This is really day 1, lesson 1 of LabVIEW. I suggest that you do the online tutorials if you want to do a project. Being able to add a shift register is nearly always a must and something basic.
Rgs,
Lucither.
Message 4 of 12
(3,512 Views)
I allready found how to do it.
But I'm not able to compare 2 states.
With the shift register, the output will become the same as the input, so not the alarm before the current alarm.
I know that it would be possible but and it should be easy, but I don't see how.
Message 5 of 12
(3,508 Views)
Hi Cheese,
Have attached a small example.
Rgs,
Lucither
Message 6 of 12
(3,503 Views)
Hi there,
I'm using Labview 8.2, and cannot open your file because you made it with a newer version of Labview.
Can you save it as an older version.
Kenny
Message 7 of 12
(3,500 Views)
Cheese,
The best bet would be to write all this into a Action Engine goto HERE. Ben did a great nugget on them which will tell you everything you need to know. I would wrap this functionality into it so when you call the vi it will write to a log file only if it is a new alarm. Have a go, if you get stuck show me what you have done and i will assist.
Rgs,
Lucither
Message 8 of 12
(3,500 Views)
Here it is in 8.2
Message 9 of 12
(3,497 Views)
Thanks, but I will explain my problem a little bit more clearer.
I have an array(string).
Out of this array I will filter a part with the "Index Array" function.
With "Index Array" I will get the state of the action.
This state I want to "save"(in a shift register, as you said) until a new action comes up, then I have to write this one to the logfile and save in the shift register.
And I don't want to put all the alarms in a scroll down menu, because I'm talking about a whole list of alarms.
Another thing, the maximum length of the logfile is 100 lines.
Do you also have a solution for this?
Kenny
Message 10 of 12
(3,484 Views)
