Comparator realisation: input signal - waveform, threshold - double constant
How to realise comparator, where input signal is waveform-type (coming from DAQ) and threshold is a double constant.
These two types are incompatible, so some conversion should be done. Which one ?
Pavel
Message 1 of 24
(5,546 Views)
The waveform is a cluster of 4 things: Array of DBLs, t0 (timestamp), dt (DBL), and attributes (variant). You can access the array of DBLs if you need.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 2 of 24
(5,541 Views)
Hi Pavel,
what exactly isn't compatible here?
Comparing a waveform with a scalar DBL value…
Message 3 of 24
(5,528 Views)
I assumed he was trying to use the "threshold" VI.
Cheers
Message 4 of 24
(5,520 Views)
Hello James,
Thank you for feedback. Here is fragment of my VI.
The signal acquired from DAQ is then transformed inside of block "Lorentz Transform" (on the "Lorentz Transform" output the data is still waveform-type) and then should be compared with threshold.
When I transform wafeform in 1D array and apply it to comparator, discrepancy persists: array cannot be properly compared with single value - connection to LED is broken.
Does exist some example, where data is acquired by DAQ and then this stream of double values is compared with a threhold: when the acquired runtime value is greater then threshold, LED is ON.
Pavel
Message 5 of 24
(5,515 Views)
Hi James,
I assume we should explain Pavel the advantage of providing a good example (VI) of the exact problem…
Message 6 of 24
(5,513 Views)
Hi Pavel,
Your conclusion is: I cannot compare because I cannot display the result of the comparison?
You can compare an array to a scalar!
But you cannot display an array in a scalar boolean indicator!
Either use an array of booleans or a suitable boolean operation like "AND array elements" or "OR array elements"…
Your should check your wording: a waveform contains (usually) more than one value!
So you need to define, when the LED should be ON: when all values are above your limit or when atleast one value is above the limit?
Message 7 of 24
(5,507 Views)
Hello GerdW
My case is similar to the following setup:
  • low frequency (e.g. 0.5Hz), amplitude 1V SIN is applied to DAQ
  • the threshold value is 0.5V
Is it possible to put LED in VI, that in runtime changes to ON when SIN is more than 0.5V and OFF if it's less than 0.5V ?
Pavel
Message 8 of 24
(5,486 Views)
Like GerdW said, you have an array of values (multiple DBL values) that you are comparing to your threshold. You need to define the criteria that the LED will show True. Is it when all values are above threshold? When the first value is above? When the last value is above?
There are many possible ways to do this.
Cheers
Message 9 of 24
(5,468 Views)
Ok, I see.
Thanks. Probably should I redefine the problem ... for example create different acquisition branch with number of samples = 1 ?
Message 10 of 24
(5,462 Views)
