CompactRIO
i havebeen tryin to simulate a motor with the help of compactRIO NI 9263 module.It deosnt seem to respond.i have used neccesary transisitor diodes and resistors needed. is ter a way i can check if the output is coming from the module when it is run
(2,727 Views)
How you have connected the motor to the cRIO? Are you sure that your code doesn't have any flaw?
(2,718 Views)
problem solved .. thanks anyways
(2,697 Views)
