Compact RIO Developer's Guide
What has happened to the downloadable bioreactor example (p. 17 Compact RIO Developer's Guide)? When I click on the link " LabVIEW example code is provided for this section." in the guide, it's some "Turbine Testing Example". I don't think this is the correct corresponding example for the bioreactor.
(3,875 Views)
Anyone out there have an answer to this?
Miriah?
(3,835 Views)
Page eleven of the CompactRIO Developer’s Guide contains the Turbine Testing System example, but I have been unable to locate the bioreactor example you mentioned.
Looking through the guide, page seventeen discusses when to use Scan Mode in CompactRIO applications.
It is possible that you are working with an older version of the Developer’s Guide. Could you please have a look at the guide posted at https://www.ni.com/en/shop/compactrio/compactrio-developers-guide.html and see if you can locate the section you are interested in?
What type of behavior/code architecture are you looking for?
Best Regards,
Cameron
(3,804 Views)
Cameron,
I am working with 2012 Developer's Guide. I think the bioreactor is more applicable to my application than the wind turbine. Is it's example code available somewhere?
-Russ
(3,792 Views)
Hello Russ,
It appears that the old bioreactor example is no longer hosted by National Instruments. However, I highly recommend investigating the “Tank Control Reference Example for Machine Control”  example program hosted on our Support page.
Cameron
(3,768 Views)
