Compact Fieldpoint XML / File Error Codes
I am new to these boards, so I guess I posted this question in the wrong place at first: http://forums.ni.com/ni/board/message?board.id=170&message.id=230583.
I'll repeat it here hoping that someone can help:
I am writing a system that I first test on the PC and will later download to a Compact FieldPoint (cFP) that I have no experience with so far, and do not have available yet.
I know I can define errors in a XML format in a Text File using the Tools>>Advanced>>Edit Error Codes tool in LV.
However does any know if this XML Text File also will be downloadable to the cFP and used tranparanly? Or do I have do create my custom errors in another way that works on both the PC and the cFP ?
Thanks for any tips !
Geir Ove
(2,851 Views)
I guess I ended up posting on the same forum. Someone at the LAVA forum told me to post at the FieldPoint forum at NI. So I went to NI's cfp seciton and selected "Discussion Forum" not being aware that I would end up post in the very same forum that I have alreaded posted in. Confusing.....
Anyway, I still would like help with the question, and sorry about the double posts.
Geir Ove
(2,848 Views)
