Compact Fieldpoint XML / File Error Codes
I am writing a system that I first test on the PC and will later download to a Compact FieldPoint (cFP) that I have no experience with so far, and do not have available yet.
I know I can define errors in a XML format in a Text File using the Tools>>Advanced>>Edit Error Codes tool in LV.
However does any know if this XML Text File also will be downloadable to the cFP and used tranparanly? Or do I have do create my custom errors in another way that works on both the PC and the cFP ?
Thanks for any tips !
Geir Ove
(2,853 Views)
No answer here, since I am eager to find the solution to this, I will try to post this on Lava as well.
Geir Ove
(2,840 Views)
