Communication with the ContronTechniques Unidrive
Communication with the ContronTechniques “Unidrive” frequency converter
I want to control the ContronTechniques “Unidrive SP” frequency converter via LabVIEW. The coverter is connectet by ethernet with the SM-Option module called “SM-Ethernet“. An ingineer from ControlTechniques said it should work with the modbus protocol TCP/IP. Anyone know of LabVIEW driver for the converter or any infos to programming the driver. Follow the link to the manual (Manuals-Products-SM Options-SM Ethernet and Manuals-Products-AC Drives-Unidrive SP-User Guide and Advanced User Guide).
http://www.controltechniques.com/downloads/manuals/manuals_frame.htm?manuals.asp&mainFrame
(5,688 Views)
Hi Pascal,
You could try the Modbus LabVIEW Library. This is a bit buggy as can be seen by the comments on the download page, but should give you a big boost in creating code to program your instrument.
Hope this helps you.
Regards
JamesC
NIUK and Ireland
(5,675 Views)
This thread has an example to read holding registers over ethernet.
https://forums.ni.com/t5/LabVIEW/Modbus-examples/m-p/249832/page/2?view=by_date_ascending
(5,662 Views)
Look at the Labview DSC add-on module.  Not cheap but it makes modbus communication very simple.  Three steps:
1 - Create and configure a modbus server for either TCPIP or serial communication.
2 - Create and configure shared network variables that are bound to the Modbus Server.  Each variable is configured to points to a particular register or bit in a register.
3 - Place the shared variables in your vi and simply read or write to them.
(5,655 Views)
