Communication software with DAQ aquisition
I'm rather new to using labview and I having an issue with a test Data Aquisition lab I'm trying to setup using  NI-DAQmx 6008, I installed it but there no comunication with software.What I can do the Daq assistent doesnt for configuration.
Rgds
Antonio Lourenco
Message 1 of 9
(3,804 Views)
Have you installed the DAQmx drivers?  Do you see the device in Measurement and Automation Explorer.
Message 2 of 9
(3,785 Views)
Yes I have installed the driver and i saw the device in Measurement and Automation Explorer, please coul you same attached print screen.
Message 3 of 9
(3,774 Views)
Here are more print screen please help me.
Rgds
Antonio Lourenco
Message 4 of 9
(3,772 Views)
I see you have LabVIEW 13.
Which version of the DAQmx drivers did you install?
Did you install them AFTER installing LabVIEW?
Message 5 of 9
(3,758 Views)
The version is NI-DAQmx 9.7.5
I Installed it after install labview 13.
Rgds
Antonio Lourenco
Message 6 of 9
(3,754 Views)
According to this https://www.ni.com/en-us/support/documentation/compatibility/16/ni-daqmx-and-labview-compatibility.h...  that combination should work.  Perhaps there was an issue with the installation and you can try install DAQmx again.
Are you sure it was the full DAQmx and not the run-time engine?
I would try downloading and installing DAQmx 16.1 which is the newest version of DAQmx that still works with LabVIEW 13.
What happens if you double click on the DAQ Assistant node?  It should open automatically for configuration when you drop it, but somewhere there is a setting that can disable automatic configuration.  It is very odd that your MAX screen doesn't show any symbol to open the tree further for the Software branch.
Oh and be careful about showing your splash screen with your license number.  You should erase that part out.  I'll ask a moderator to fix it.
Message 7 of 9
(3,751 Views)
The size of this driver is 1.83 G.
Message 8 of 9
(3,732 Views)
Using LabVIEW 2013 you can update your DaqMX to version: 16.1. I am not sure if that will help or not.
You could also post your code so we can take a look to see what you are doing there.
Tim
GHSP
Message 9 of 9
(3,715 Views)
