06-30-2008 09:15 AM
06-30-2008 09:46 AM
07-05-2008 07:26 PM
Hi Andrew,
Was the LabWindows program used with a National Instruments DAQ board? AO_VWrite is a Traditional NI-DAQ function. As you said, it scales a value to a binary number and outputs that to the specified channel. The NI-DAQ VI that is similar is AO Write.vi. Using DAQmx you would create an analog output task and then use the DAQmx Write VI.
For serial communication using VISA VIs, you will need to know the command set for the PEM.
