Communicating with Rhode and Schwarz instruments
Im using an R&S FSC3 spectrum analyzer and an SMB100a generator and i installed all the necessary drivers for the both of them . i have the FSC 3 connected via USB and the SMB100A via ethernet cable (TCP/IP).
im trying to write a labview code that reads frequency and amplitude of the FSC 3 using labview so if anyone has an experience using rhode and schwarz instruments to read data let me know
Message 1 of 12
(1,945 Views)
R&S website provides drivers and examples
FSC | Driver | Rohde & Schwarz
SMA100A | Driver | Rohde & Schwarz
https://tmesystems.net/
Message 2 of 12
(1,913 Views)
The exemples provided in the website dont work on FSC 3 . Some of the function blocs that come with the drivers aren't compatible with the fsc 3 . I tried modifying them but i still get errors everytime i try to use them
Message 3 of 12
(1,877 Views)
Hi Hetrx,
Which errors did you encounter?
In which way are those VIs "not compatible"?
What have you tried?
Do you have the (programming) manual for your device?
Do you know all the commands and their parameters for your task (from reading the manual)?
Message 4 of 12
(1,867 Views)
basically every single one of them . take for exemple this one that displays peak list ( frequency and amplitude )
take for exemple the rssafsup configure display update.vi bloc . an error shows me that that bloc isn't compatible with fsc spectrum analyzers . it works on other ones such as fsp etc ..
Message 5 of 12
(1,852 Views)
Hi Hetrx,
Did you try to switch off the IDQuery?
Did you try to adapt the IDQuery to accept your specific device?
Message 6 of 12
(1,845 Views)
can you explain further more please ?
Message 7 of 12
(1,822 Views)
Hi Hetrx,
Open the VI from your last message and you will see a button labelled "ID Query". This button is TRUE by default and so it triggers a certain action in the first Init subVI…
Did you look into the Init subVI?
Did you learn what the IDQuery does?
Did you debug your VI using highlight execution, probes and breakpoints?
Message 8 of 12
(1,818 Views)
i did all of the above .. and im still getting the same error . i even tried removing the rssafsup configure display update.vi but another error popped up that has to do with sweep time
Message 9 of 12
(1,815 Views)
Do you have manuals for your hardware? That would be a first good step for Gerd (and any of us) to see what doesn't jive with your VIs.
Message 10 of 12
(1,807 Views)
