Communicate to a 34970A from 2 VI's at the same time
Im using an Agilent 34970A and i need to have two different VI's running at the same time, one is retrieving measurements from 5 channels of the 34902A (every second) and the other controls the actuator module, at the runtime sometimes it send and error and i cant keep controlling or measuring anything, how can i do it or check if the equipment its in use before trying to use it?
(2,933 Views)
You can use the VISA Lock/Unlock functions. There is an example called 'locking.vi'.
(2,929 Views)
Ok that sounds good, just one more question, when the VISA is locked, and another VI tries to acces to it, it sends a locked error right? will that locked error sent to the equipment too or it just wont let the VI access to the equipment?
(2,922 Views)
Accepted by topic author ponchio22
No, nothing is sent to the instrument.
(2,914 Views)
Ok Thank you for your time, that helped me a lot.
(2,906 Views)
