Communicate from LINX to DAC(MCP4725) via I2C
I have  trouble connecting LINX with my DAC(MCP 4725).
I dont know which register i should choose  to write in the DCA register to alter the output voltage level.
And I doent know how to change the operating element for altering the bit-value into a slider.
Can anyone help with a small example code?
Everithing you need is atached.
 Cheers
Best Regards
(7,691 Views)
I have troubles too.
Could you help me please.
 I donn´t know how to manage de data to write I2C code.
(7,651 Views)
@FloMaye ha escrito:
 Cheers
Best Regards
Hi!!!  Try with this VI.
I modified the last vi that I posted here. I based myself on the arduino file dac02
Look this
I´m using DAC MPC4725 from Sparkfun. There the adress is 0x60
Let me know if this help you
(7,645 Views)
@ykgr08
Thank you, it helped a lot!
I could solve the problem.
(7,628 Views)
It's Great. It is working absolutely fine with no errors. Thank you, Bro. Can you help me in interfacing ADS1115 ADC chip with LINX?
(7,452 Views)
