Commucation between CRIO and PLC
Hi guys,       I'm trying to build commucation between my CRIO9066 and PLC300, which means I want the CRIO to obtain data from PLC, but I don't know how to implement it, could anyone give me a hand?      By the way, I've made it possible to communicate between Labview and PLC by using OPC server, I wonder if it works too in communication between CRIO and PLC.
Once for all!
Message 1 of 8
(4,751 Views)
Can you connect to OPC-server from cRIO? (similas as from PC).
If no, make vi on PC which will get data from OPC and send it to cRIO
Message 2 of 8
(4,741 Views)
I'm working on that, thanks for you reply!!
Once for all!
Message 3 of 8
(4,738 Views)
Accepted by topic author Vidasll
To my knowledge, you cannot connect to an OPC DA server from a cRIO because it is not a windows target and OPC DA uses DCOM for communication. If it is an OPC UA server, you can definitely use the LabVIEW API from a cRIO.
You could also check if there are other ways to communicate to the PLC such as Modbus.
Message 4 of 8
(4,713 Views)
Depending on how you want to use it but you can use this API. http://snap7.sourceforge.net/
Generally it works fine but If you want a more reliable method, I use SP7 Toolkit (a product of Data Ahead, NI Silver Alliance Partner). You can give it a try.
Emre
Actor Framework rocks!
Emre TUZUNER
Message 5 of 8
(4,688 Views)
    Thans for you reply, I'll give it a try!
   Regards!
Once for all!
Message 6 of 8
(4,667 Views)
Hi Matt,   I've considered your suggestion, and I wonder if it is an accessible way to achiece that by installing Linux system to my computer.
Regards!
Once for all!
Message 7 of 8
(4,665 Views)
Problem solved!
Thanks for your suggestion, it does help!
Once for all!
Message 8 of 8
(4,573 Views)
