Comment code
>The sequence works too but it is very thick. You must
>state that the structure is solely for comment
>purposes because it is usually used for coding.
>Otherwise, sequences have no performance issues: they
>force execution order on the compiler but the code
>execute at the same speed.
State? Do you mean 'state' in the description and tip? (No need to reply if this is what you mean.)
!!!Thanx!!!
Message 7 of 12
(1,992 Views)
Thank you for the decoration tip.
Message 8 of 12
(1,992 Views)
