Command Line: Add two numbers and return result
We can pass arguments to the executable with App.Args property and Pass all command line arguments to application in the executable build specification.
I'm looking for a way to return value from LabVIEW executable after execution to the same command line (like print output in C or python).
I notice that command returns back soon after I pass back on cmd and later LabVIEW gets triggered.
PFA: Executables and Builds used for this purpose.
Ajay MV
(1,506 Views)
Hi Ajay,
Read somewhere that LV is not a command-line application to return something to CMD or interactively operate with CMD, this means LV exe can only take in arguments from CMD. Someone on LAVAG created a wrapper that allows you to work around this limitation.
Santhosh
Soliton Technologies
(1,500 Views)
