Comet Graph Timestamp Input on X Vector
When I use the new 3D Comet Graph, If I wire a tiemstamp array to a convert to dbl then put it into the 3D Graph VI it seems to have a problem.  I went to the graph menu panels and set teh x input to absolute time formatting and it still dont work.
Help!
(2,678 Views)
Hey,
Just looking at your problem. Do you need to include the date in your time calculations? Also, would you not be better including a reference time stamp, subtracting it from your values to create an array of 'time since recording started' values?
Just some thoughts, hope they are useful to you.
Chris
National Instruments - Tech Support
(2,662 Views)
