Combining/Synchronizing Digital and Analog Data
Hi Everyone!
I am using a NI 9189 with the NI9205 and NI9425 to measure analog and digital data respectively.
What I want to do is create an array with both the analog value and digital data. The problem I am having is the I am doing NChannels NSamples for the Analog Read Task and NChannels 1Sample for the digital task. Due to this difference, when I concatenate the arrays it only shows the digital state once per loop iteration. I want them synchronized. Does anyone know how to fix this?  I tried messing around with NChannels NSamples with the digital task, but I was having difficulty.
Any help would be appreciated!
(2,878 Views)
So I just found this example online, but I am still having problems. It errors saying DAQmx read does not match the type of channels in the task.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019PBVSA2&l=en-US
(2,863 Views)
I don't have experience with Compact DAQ, but have used USB and PXI DAQ devices.  What happens if you write a routine that does just one of these?  Does Analog alone work?  Does Digital alone work?  If both work stand-alone, then the problem is combining them.
When I've configured DAQ input, I always wired the Number of Samples in the Timing function (rather than assume a default).  I also wired this to the Read function (to force it to read all of the points) -- I never used -1 (and so far haven't had a problem doing this).
So do some experiments, see precisely where the error is occurring, and see if specifying # of samples and using the same value for the Timing and the Reads helps.
(2,856 Views)
