Combining Switch and Time Measurement Start.
Hello folks,
I´m having troubles solving a problem with a function on my bachelor thesis. My actual plan was to 'activate' some relays (indicated by a LED) simultanously with several checkboxes and some boolean switches (Sync. part), wired with an AND-operator. By 'activating' all relays marked with an checkbox, an measurement with the starttime should be shown on the right side (attached VI - v8.5). At the end of the test, by pressing the stop button, the ending time should be shown.
Now, the 'General'-switch has  'Switch-on-pressed'-properties, that doesn't go along with my stacked sequence to take the time at start/end. The start-button is configured as 'Latch-when-pressed'.
Does anybody know, how I can fix this, so those two switches are connected with each other?
Thanks in advance for any help.
Greetings,
Andy.
Message Edited by glaxi on 08-12-2008 11:25 PM
(2,619 Views)
 Hi Andy,
i am not for sure if this is working, cause some of the subvi's are missing so i can't try, but maybe you could just create a local variables and connect them with some logic?
regards
Tobias
(2,587 Views)
