Combining Several enum strings
I need to be able to combine several enum strings together and have an output of one enum string. I know with string text application you can combine the strings into one using Concentrate String application. Is there any such application or method to do the same with enum strings?
(4,167 Views)
Hi artorus,
You can combine the strings of two enums using property nodes.
Please refer to the attached VI (8.2).
PO.
(4,161 Views)
You can also use the "Format Into String" function.
(4,150 Views)
