Combining Radio Button logic and Ring Control Logic.
I want to control ring control items based on the selection of radio buttons.
How can I do that
Message 1 of 10
(4,050 Views)
Which control do you mean? You mean text ring controls?  You can use a value property node. From the radio buttons you can make a value and write that to the property node.
Message 2 of 10
(4,047 Views)
Hi krjasani,
I guess you want to change/set ring items based on some conditions: use the "Strings[]" (or "Strings and Values []") property of the ring…
Message 3 of 10
(4,040 Views)
Thanks for response.
I want functionality where if user select Radio Button-1, then select item from list-1 like wise.
Please see attached snap for understanding.
Message 4 of 10
(4,037 Views)
Hi krjasani,
to set ring items you should use the "Strings[]" property…
Message 5 of 10
(4,027 Views)
Message 6 of 10
(4,025 Views)
Hello, Can you share VI ?
Message 8 of 10
(3,986 Views)
Omar
Message 9 of 10
(3,969 Views)
Message 10 of 10
(3,963 Views)
