Combine Character Sets (OCR)
Dear all,
I´d like to create a big database with characters for OCR. I intend to create one Character Set (.abc file) for every font of interest, e.g. Times.
My question is, is it possible afterwards to combine different character sets in a single character set (one containing several fonts)?
I have tried in the VISION ASSITANT but couldn´t find any option for that.
Esteban
(5,981 Views)
(5,922 Views)
Accepted by topic author Arroyo
where is my message Robot Mad
Hi Esteban,
open one file, hit the merge button (see pic), select another file.
Kind regards
Heinz
(5,919 Views)
Hi HeinzG,
 I was trying to do it in the menu of edit character set file. -.-
Thank you very much for your answer.
Esteban
(5,914 Views)
Hi Esteban,
you are very welcome. Good luck with your project...
Best regards
Heinz
(5,892 Views)
Hi Heinz,
Thanks 🙂
As you seem to have experience with the OCR tool, let me ask you another question.
I was using OCR in the vision assistant and then export my script as a VI. Surprinsingly, without changing any parameter, I obatained different results. Had this happened maybe to you?
If you have a minute, please see this thread.
http://forums.ni.com/t5/LabVIEW/Why-do-the-results-between-the-OCR-in-the-Vision-Assistant-and-a/m-p...
Thanks again! 😉
Esteban
(5,880 Views)
Hi esteban,
did you solve the problem you were facing with the vision assistant of merging character files and getting it properly in the VI. If so could you tell us how? we are also facing the same problem
(4,201 Views)
