Combine 3 intensity graphs
Hi, I want to simulate heat distribution from 3 sources. Is it possible to combine/merge 3 looping intensity graphs into 1 intensity graph? I tried to use min max function but the result is weird.  Could you help me with some suggestions?
Thank you very much in advance!
(1,841 Views)
Hi Jodano,
Do you want to display those 3 images next to each other in a new graph?
Use array functions to build a larger graph…
Or do you want to use some math to calculate a combination of those 3 individual images?
What about adding them and change the scale? (Maybe you want to normalize those graphs to a common scale before adding them…)
(1,830 Views)
Can you explain your use of the word "weird"? What do you expect to see instead?
Also please give attached pictures reasonable names. Which one is the weird one???
(1,826 Views)
The later one
(1,824 Views)
I tried to use minmax function, but it only allows 2 inputs. So I link 3 inputs like this
And the result is this
(1,821 Views)
What is weird about it?
(1,819 Views)
This is heat distribution simulation, so the temperature value should spread more evenly. On the result, the left-bottom get larger, while the left-top and right-bottom part get smaller. So using min-max function is wrong here
(1,797 Views)
