Combine 3 2D arrays in a certain way
Let's say for example I have the following 3 arrays:
123
456
789
and
321
654
987
and
213
546
768
and I want to combine them to the following array:
123 321 213
456 654 546
789 987 768
What could I do? I thought about transposing each of them first and then using build array, but that doesn't seem to work.
Message 1 of 11
(1,422 Views)
Maybe like this?
(note that the "built array" inside the loop is in concatenate modes (right-click...)
Message 2 of 11
(1,408 Views)
Accepted by topic author alainschaerer
Hi Alain,
Transpose each input array, BuildArray with 3 inputs in concat mode, transpose the output…
Message 3 of 11
(1,374 Views)
This works
Message 4 of 11
(1,362 Views)
I would go with my solution. A single FOR loop is probably preferred over four transpose operations, even though the compiler will probably optimized it into similar binary code.
Message 5 of 11
(1,354 Views)
Thanks guys. I used the 4 transpose operations because performance wont be an issue. But thanks to all of you.
Message 6 of 11
(1,342 Views)
My comment was based on code simplicity, readability, programming speed, and diagram area, even though performance might be similar. 🙂
Once you have the concatenate operation, placing a FOR loop around it is more than 3x faster than herding four(!) transpose primitives. 😮
(That's like tripling your hourly wage!)
Message 7 of 11
(1,325 Views)
I really don't understand your code.  Neither the inputs, nor the outputs match what the OP requested.
Message 8 of 11
(1,294 Views)
Since I did not like tediously entering 27 values, I entered 9 unique values in a 3x3 pattern and modified these to created A, B, C in three wires (and display in three indicators for reference). Then I used the data of ABC to create the requested arrangement,
So, three 3x3 2D arrays merged into one new 2D array as requested. Ignore the values, it's all about the final arrangement. 😄
Task from the subject line: "Combine 3 2D arrays in a certain way"
(Your snippet is too new for me to look at and see what the default values are, but I was puzzled by the orange color for integers)
Message 9 of 11
(1,286 Views)
I saw it as 9 values in 3 arrays of size 3x1.
Message 10 of 11
(1,268 Views)
