Combinations of a number of elements
Hi guys,
I am trying to list the total number of combinations of a number of elements. Let's say that I want all the combinations of
a,b,c,d,e,f,g,h,i, j
There are 1024 of these :
-; a, b,c,...., ab, ac, ad,.... abc,
and so on
I have no ideea how to find these. Any clues ? (the number of elements, 10 here, is just an indication... for 14 elements I should get 16384).
(1,889 Views)
Have you searched the internet, or even this forum?
(1,845 Views)
One possible idea (sorry, posting by phone).
Count in binary from 1 (or 0) to 1111111111 (each bit representing one character) and create the corresponding string for each. Code probably fits on a postage stamp. 🙂
(1,841 Views)
Accepted by topic author nitad54448
See if this can give you some ideas (indicator is shown twice (scrolled to each end)).
This is pretty explicit. I am sure there are fancier versions if performance matters. Not sure what primary sort order you want for the output (alphabetical? By length?, etc.)
(1,800 Views)
no need to be that harsh, yes I searched this forum (maybe you could point me to a link that I missed)
N
(1,775 Views)
Hi
Thanks for the solution, it works very well.
To explain further what I was trying to do : I want to make a programmable "resistance" by using a switch and a multiplexer/matrix. I am putting 10 different resistances in parallel and programming with channels to cross. I converted your program to output arrays of booleans (which close/open channels) and it works very well.
(1,719 Views)
