Com1 Modem Read
I want to send :
1.  AT <ENTER>  response should be OK
2.  AT+CMGF=1 <ENTER>    response should be OK
3.  AT+CPMS="SM" <ENTER>   response is :      +CPMS: <used_space>,<max_space>
4.  AT+CMGL="ALL" <ENTER>    response  is :
+CMGL: 1,"REC UNREAD","+31625044454",,"07/07/05,09:55:16+08"
Test message 1
+CMGL: 2,"REC UNREAD","+31625044454",,"07/07/05,09:56:03+08"
Test message 2
OK
5. AT+CMGR=2 <ENTER>   response is SMS no. 2 from previous step or any thong I want
****  point 4 or 5 which I want to read and send it to text file on my PC.
Message 21 of 24
(838 Views)
If you put a small delay it will probably work
It whould help if you posted the code..
We are trying to help !
Message 22 of 24
(831 Views)
Well, what I see from the forst time it works is that there is almost 3 seconds between the command being sent and the data being received.  What delay are you using between your write and read?  You should start with significant delays to make sure things are working.  Since your code closes the port immediately after the read, you may be getting data that you do not see.  The serial port monitor program will not see data coming from the SIM after the port is closed.
Message 23 of 24
(829 Views)
The Program works fine.
Thanks to all Smiley Wink
Message 24 of 24
(805 Views)
