Com-interop Enum to Switch Case in Lab View
I am using a COM-Interop in Lab-view, I have some functions that return an enum, I want to make a switch-case structure on this enum but I can't, but when I put an indicator to function output I see that the enum returned as expected.
so, my problem is I can't make this switch-case from my enum that exported from interop dll
Message 1 of 10
(4,088 Views)
any idea?
Message 2 of 10
(4,035 Views)
Can you give some example code? How does your COM-Interop work?
Message 3 of 10
(4,028 Views)
here is an example of a function return from the interface called that called "ITestList" it's return the eTestType enum
Namespace DataChannel.Interop
    Public Interface ITestList
        Function GetCount() As Integer
        Function GetTestAt() As Integer
        Function GetTestTypeAt(index As Integer) As eTestType
    End Interface
End Namespace
Message 4 of 10
(4,010 Views)
And where and how is eTestType defined? If it is a public definition then you can create an instance of it in LabVIEW. Otherwise not. But you need to know where it is defined, LabVIEW won't know on its own.
Rolf Kalbermatter  My Blog
Message 5 of 10
(3,999 Views)
yes it's public and I can instance from it, but I can't link it with node output or switch-case I'm totally beginner 🙂
Message 6 of 10
(3,994 Views)
@Peterboshra wrote:
... when I put an indicator to function output I see that the enum returned as expected.
Can you expand on that? How does that look in LabVIEW? What do you expect and what do you get?
Message 7 of 10
(3,964 Views)
this is the output and the ring indicator on it I need to make a switch case from this enum output and according to the output the case switched and do some action
Message 8 of 10
(3,959 Views)
You probably need to use the "Coerce To Type" function (under palette: Programming → Numeric → Conversion"
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/functions/coerce-to-type.html
Message 9 of 10
(3,941 Views)
Ahhh now I understand. Since .net enums are really more sparse enums (even if they are fully consecutive) and LabVIEW doesn't have sparse enums, it translates them into a ring control. But a ring control only has string labels in the UI element, not as part of the data type. And therefore you can't select on that string as it is not part of the datatype.
If and only if, this enum is consecutive and not sparse (sparse meaning that it doesn't have a consecutive increasing numeric value corresponding to the enum string, but with some holes in it) you can right click on the ring control and select "Replace" and select an enum from the LabVIEW palette.
If you do that with a sparse enum, LabVIEW will reassign the enum values with consecutive increasing numbers and you get a mess as the numeric values don't correspond to the original numeric enum values anymore.
Message 10 of 10
(3,933 Views)
