Colorful Decorations
How can I draw colorful edges on decorations that are placed on the front panel. In the attached vi, look on the front panel and you will know what I am talking about.
Message 1 of 8
(4,400 Views)
When selecting the color, hit the space bar to switch between bordor color, fill color and both.
Check the online help.
Message 2 of 8
(4,393 Views)
Look in the Decorations palette. Use the flat box, set the foreground color for the border.
Message 3 of 8
(4,390 Views)
I can find anything related to changing the color still. I find the flat boz in the decorations palette but nothing fro the color. Also, I was trying selecting the flat box and putting it on the front panel and clicking the right click, but all it says is ORIGINAL SIZE or SCALE OBJECT WITH PANE.
Message 4 of 8
(4,387 Views)
You need to change to the paint brush tool first.
Message 5 of 8
(4,381 Views)
Now, I am able to paint the flat box but still not the edges of the box. Is there anything else I am missing?
Message 6 of 8
(4,370 Views)
That's where you need ot follow altenbach's advice.  If you use the spacebar in the color picker pop-up window, you can paint the foreground color, backgroung color, or both.  You can also use "f" to select foreground and "b" for background.  The trim is the foreground color.
Message 7 of 8
(4,364 Views)
Thanks, I got it.
Message 8 of 8
(4,358 Views)
