Color printing issues
I am having trouble printing in color, the background is printed in gray even though I have changed the color.
(3,806 Views)
Which version of LabVIEW are you using?
There is a bug in LabVIEW 8.0.x, which prints wrong background color.
It's fixed in 8.2
Message Edited by zou on 10-02-2006 01:54 PM
George Zou
(3,802 Views)
It is possible that your printer driver, or even the printer itself, does some "color correction". Try to turn it off. (For example on a Xerox Phaser printer, you would set the color correction to "none".)
What is your LabVIEW version? I remember struggling with similar issues in the distant past where I "fixed" it by placing a white decoration in the back.
I just did some casual testing in LabVIEW 8.20 and everything turns out perfectly white. Maybe they also fixed some things on the LabVIEW side. 😉
(3,798 Views)
This was reported to R&D (# 3R3F7UA3) and was fixed in LabVIEW 8.20 (as mentioned above). Here is a link to the current evaluation software download for LabVIEW. You can also find more information here:
Hope this helps!
Charlie S.
Visit ni.com/gettingstarted for step-by-step help in setting up your system
(3,766 Views)
