Color Temperature Calculation with Optic Sensor
Accepted by topic author Sundar...
I tried that zip archive on a different PC and it seemed to work fine. I have recreated and attached again just in case and also provide a 8.6 copy.
If there are still problems, please let me know exactly what error you are getting...
Cheers,
-Jolt
Message 11 of 17
(6,323 Views)
some infomation for your reference-spectrum analyser
Message 12 of 17
(6,244 Views)
How to change Ra resulotion to 0.1? please help me, thanks. attached is some color source data for your reference. ronke@163.com
Message 13 of 17
(5,977 Views)
Hello Ronke,
I did not look at your color source data. However, because the rendering indices are by definition integers and the "Ra" value is an average of the first 8, the resolution cannot be less than 0.125.
That being said, while the code is less than perfectly constructed feel free to dig back to where all these things are calculated and remove the "round to nearest" function (located near the output of the aptly-named "Ra Calc.vi"). This will invalidate some of the actual science behind the numbers but will give you your "resolution"...
Cheers,
Message 14 of 17
(5,955 Views)
Also, I noticed that the back-save to 8.0 I used in the posted examples actually causes a little problem in the code. Please let me know if you are using the 8.0 files (the 8.6 are perfectly fine).
Cheers,
Message 15 of 17
(5,954 Views)
The spectrum analyse.zip is very useful. Do you have a similar VI (from raw spectrum to color paramters) which provides the dominant wavelength? Is the source code of this program avalable so as I may update it myself? thank you.
Mike
Message 16 of 17
(5,494 Views)
Hello all.
I realize this is quite an old post, but if anyone has stumbled upon this thread because they have use for spectral analysis and/or composition, please check out the ColorTools package available on the LabVIEW Tools Network. A thorough description and trial of the package are available here: http://interfaceinnovations.org/colortools.html . In addition to a LabVIEW Toolkit, we have executables available for use with LabVIEW RunTime.
Please feel free to contact me directly here or at support@interfaceinnovations.org
Kind Regards,
Colin
PhD ChemE, CLD, Alliance Partner : www.interfaceinnovations.org
Message 17 of 17
(5,074 Views)
