Collecting and interpretting data in Labview
@GerdW wrote:
Hi bestecf,
I understood better, thank you now it's ok. (codes_display.png) When I change display style," \s\n" is added by .vi.
No, you don't understand that at all!
  • The VI doesn't "add" any chars when changing the display style - it simply shows them in a different way. YOU inserted those chars (SPACE and LINEFEED).
  • Don't add those "<0D><0A>" in that string constant. This is completely non-sense and shows you don't understand the meaning of the explanations in your manual. That "<0A>" is actually the "\n" in \-code display mode…
Other things:
  • You don't need to set parameters at SerialPortInit when they are the default values.
  • Use AutoCleanup! Right now there are hidden code parts…
Dear GerdW, you take great pains and also I'm trying/applying what you say. I might have misunderstood. Right now, I'm gonna try to connect device.
Message 31 of 35
(1,096 Views)
Hi bestecf,
did you understand any of my comments from previous message?
You're not even using AutoCleanup…
The command is given as "COM[,a]<CR>[<LF>]" in the manual:
  • anything in brackets is optional
  • <CR> means CarriageReturn aka 0x0D aka \r
  • <LF> means LineFeed aka 0x0A aka \n
(All these items are surely explained in your manual!)
So your command can be given as "COM\r\n" in a string constant set to \-code display mode:
Why did you use a typedef for this string constant???
Message 32 of 35
(1,087 Views)
Sorry, it's my fault. I realize that I have attached wrong files Smiley Sad
Now I've added what I did.
Message 33 of 35
(1,078 Views)
Hi bestecf,
But I dont understand in .vi, <CR> aka \s (I changed as \r), <LF> aka \n
Generic advice: Read Wikipedia on ASCII codes! (And learn this table…)
Specific advice: <CR> is NOT "\s", it's \r in \-code. "\s" is a simple SPACE aka 0x20. Read the LabVIEW help to learn about the possible \-codes!
Message 34 of 35
(1,063 Views)
Thank you very much GerdW for your advice and solution Smiley Happy
Message 35 of 35
(1,049 Views)
