Cognex DM100
Hi All,
does any one have experience using Cognex DM100s. I want to simply use it to read a barcode using labview. I read online that there is a way to do is using ActiveX but i didnt find any examples. Let me know if any one has expirence integrating Cognex DM100 in labview.
Thanks.
(4,499 Views)
You can use VISA Write/Read with the virtual COM-Port. I think the command is something like
||>trigger on
(4,455 Views)
Hi Thanks,
I will try that, do you might also know baud rate for the device?
do you maybe have an example ?
(4,452 Views)
Accepted by topic author AsadAA
115200, 8 Data Bits, none Parity, 1 Stop bits, no flow control.
(4,450 Views)
