Coercion dots
hi there, can someone suggest a solution to my coercion dots?
thank you very much.
Message Edited by krispiekream on 05-27-2008 03:44 PM
Krispiekream
(2,987 Views)
Change the datatypes of your globals to I32, or use one of these, depending on the datatype of the global:
Message Edited by smercurio_fc on 05-27-2008 03:58 PM
(2,977 Views)
Coercion dots are not necessarily a problem (although changing representation can cause you to lose data).
In this case, the coercion dots are there because your global variables are of different representation than the wire going into them, so you have two options:
  1. Change the representation of the globals to I32 (probably better, but can have repercussions in other VIs).
  2. Use the default value terminal on the primitives and a coercion to have the primitives output the representation you want.
This of course ignores the point that globals are generally problematic.
___________________
Try to take over the world!
(2,973 Views)
Turn on Show Context Help and mouse over the wires to display the data types
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(2,967 Views)
GREAT!!!
THANK YOU EVERYONE..
Krispiekream
(2,952 Views)
