Code MAXStoppedServiceError
This is my problem:
Deploying Shared Variables.lvlib\\10.23.63.97\Shared Variables deployment failed (error: -2147220693, MAX:  (Hex 0x8004032B) The configuration database is not running. Restart your system and try again. Visit ni.com/info and enter the Info Code MAXStoppedServiceError if the problem persists.).
(5,479 Views)
Hi cRIO-9215,
You try do the corrections suggested by the document on ni.com/info
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PAp0SAG&l=en-US
Best regards
Abel Souza
Engenheiro Eletrônico
LabVIEW User since 8.5
(5,457 Views)
Yes, I did. The problems remains almost the same. After the service is started the Windows 8 give me the following message:
The service has been started but stoped imediatelly.
best regards
(5,454 Views)
What MAX version are you using?
Abel Souza
(5,452 Views)
The last one: Version 5.5
I am trying to reinstall the MAX by means of the NI-DAQmx Run-Time Engine 9.7.5 downloaded from (https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html#288372)
(5,445 Views)
On NI-MAX go choose on menu bar Tools>>Reset Configuration Data , it will restart MAX to original configuration and may solve the problem.
If it don´t solve please, post Max Technical Support Report.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q0000019hceCAA&l=en-US
regards,
Abel Souza
(5,439 Views)
I too faced the same problem and the solution you mentioned solved the issue. Thanks a lot..
(2,477 Views)
