Cluster of Cluster Property from Event
I'm having an issue where a Cluster of cluster is not accessible within an Event case. This should normally work.
This should normally work and for some reason I'm getting an error for the type conversion. I tried with Cluster and Cluster (strict).
Some other conversions with such as basic control to get/change the label but I cannot access the Controls[] of that imprecated cluster.
Basically I want to replace the direct "Write" to "t0" with a control reference since I need to duplicate the event case many times and don't want to re-link every time and possibly forget to.
(1,630 Views)
Accepted by topic author Foreshadow20
Found the Error, I used the wrong conversion class.
(1,627 Views)
